Pyle PCT10 Pro 8 Plug Pro Audio Cable Tester
ENABLES QUICK CONTINUITY CABLE TESTING FOR ALL TYPES OF CABLESLED'S CONFIRM EACH CONDUCTOR CONTINUITY AND CONNECTION6-WAY SWITCH FOR SELECTING CONNECTIONS TO BE TESTED. INCLUDES INTERNAL BATTERY AND GROUND CONNECTION STATUS CHECKRUGGED COMPACT METAL CONSTRUCTIONTESTS CABLES WITH ALL TYPE COMBINATIONS OF THE FOLLOWING TYPES:6,35mm JACKS3-PIN XLRRCA3-PIN DIN5-PIN DIN4 PIN SPEAKON3.5mm JACKS9V ALKALINE BATTERY
