Maxell 212071 Maxell High Speed 4-Port USB 2.0 Hub -191127
Connect and use multiple USB devices at the same time Product Information The Maxell 4-Port USB 2.0 Hub is the solution to the problem of having too many USB devices and not enough places to plug them in. When you are trying to use multiple USB devices such as an iPod flash drive or cell phone charger all at once the Maxell 4-Port Hub makes it easy - and you can link up to 127 USB devices by connecting multiple hubs. Compatible with USB 2.0 and 1.0 ports this hub supports data transfer rates of up to 480 Mbps. The built-in USB cable and cable management system make this hub easy to use - and its small size makes it extremely portable. Product Features Allows up to 4 USB devices to work at the same time Compatible with USB 2.0 and 1.1 specifications Supports data transfer rate up to 480 Mbps (High-speed) Compatible with PC and Macintosh Link up to 127 USB devices using multiple hubs Specifications Color: White Interface: USB (USB 2.0 and 1.0 compatible) Dimensions: 1.89 x 1.89 x 0.75 (L x W x H) Weight: 35.5 g Warranty: One Year Limited Manufacturer Warranty System Requirements Windows 98SE ME 2000 XP Vista Windows 7 Macintosh OS 9.1 or greater Available USB 2.0 or 1.1 Port Item Condition: New
