Cables To Go 40060 12ft PRO-AUDIO CABLE XLR MALE to XLR FEMALE
Impact Acoustics Pro-Audio cables are made from twisted pair audio cable under an aluminum foil for maximum shielding from noise. High flexibility 7mm PVC jacket reduces the risk of cables kinking and damaging the conductors. Bright nickel plating on solid brass connectors resists wear from reconfiguring and moving equipment from one venue to another. Chuck strain relief inside the XLR connector reduces the effects of age on the solder joints and contacts. Features: 22AWG Twisted Pair construction. Foil shield and 60% copper braid. Nickel plated brass connectors. Connects balanced line outputs to balanced line inputs.
